Icons?
Can someone tell me what to do with these Icons that appear in smart content.. Got a lot of tthese.  TIA.
135 x 172 - 8K
126 x 175 - 7K
  • Richard HaseltineRichard Haseltine Posts: 111,906
    The first one is user data for a product that is no longer installed - DS doesn't automatically remove any custom categorisation or other database modifications when you remove a product, in case it's a mistaken removal or you later want to reinstall. If you do want to remove it you can do so by right-clicking on the product in the Content Library pane and choosing the delete option (default metadata will then be reloaded, when you next connect I think, so you wills till have access to the item).
    The other indicates that the product is there but does not have its thumbnail for some reason (if the product was also not wheer the database said there would also be a yellow triangle with an exclamantion mark).
  • sambucussambucus Posts: 42
    Thanks for that.
