City Dining Room - How to set up lighting
5200north5200north Posts: 249
edited June 2017 in The Commons
can anyone guide me to how to light this scene similar to the product like the photos used in the product page?
lighting has always been my weakest link.
Post edited by Chohole on
  • frank0314frank0314 Posts: 15,100
    Do you have an example of what you are working on. The room determines the type of lighting it should have.
  • Tim NTim N Posts: 193
    I don't have the set, but here's what I'd do:
    1. The light globes should be emmissive surfaces. Set the luminosity to a sufficiently high value that they light the set. Set the temperature to 6,500 K for a neutral colour. (Lower numbers will give a yellower light.)
    2. The light shades (the conical shapes) will need a glass shader applied. Warning: Some glass shaders transmit light much better than others, so try several.
    3. Put a powerful spotlight outside the window, and angle it downwards. This will provide the highlights on the floor.
    4. Optionally add an HDRI map so that you have an image outside the window and a little light coming in from the front. Rotate it as necessary.
    Hope this helps.
    Tim.
