How to freeze an object’s size and location
GuruvarGuruvar Posts: 344
Hello Sirs and Madams,
I'm new to the creative side of Daz, but have big goals with regard to creating content. Just trying to get past a few early hiccups.
On that note, is there any way to freeze an object at a particular size and location, so that when you transfer Genesis bones to it it doesn't revert to its original size/location? I thought I had this figured out, but I went to create some stuff today and it botched up.
I've exported, imported, disassembled and turned my objects inside out -- but they keep reverting to their original size during the rigging process. I figured there would be a 'clear' or 'zero' option somewhere in Daz or Hexagon, but I haven't been able to find it. I did read that you can do something with the Joint Tool, but I haven't been able to get it to work.
Any help would be greatly appreciated.
    This is not a query relevant to the developers forum, so moved to Nuts and Bolts.
    If you are making clothing for Genesis, I believe that you are supposed to use the Base shape to model around. Clothes made for one morph of Genesis will generally fit another. I take it you have made clothing to fit a small morph of Genesis? I think you need to select 'Reverse shape from source' or words to that effect.
    Sorry I can't be more helpful, but I am sure someone who can will be along shortly.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    If you have adjusted a mesh to fit Genesis, export it as OBJ and then import that OBJ again (using the same preset for both import and export) to freeze it.
