Viewport darkened?
JQPJQP Posts: 527
edited June 2017 in Daz Studio Discussion
This is really weird. DS viewport is now darker than it was before. I thought it might be my monitor, because it's starting to die on me, but I just checked two renders of the same scene, one before the change, and one after, and the renders look the same. It's just the viewport that's darker.
I ran through everything in edit>preferences>interface, turning stuff off/on and applying, but that's not it. I reinstalled DS and that didn't help. Anyone ever experienced this? It's a pretty significant change. Everything in viewport is just...darker. Dark enough to be kinda hard to see. Only thing that happened in-between was I had to do a hard restart of Windows while I had a scene open. Next time I fired up DS, weirdness.
Edit: k I just realized that my before/after test makes no sense, since it's the same monitor displaying both. Still, I don't notice anything else seeming darker. Just DS viewport.
It almost seems like the headlamp is dimmer. Is there any way to change headlamp brightness?
Post edited by JQP on
  • Richard HaseltineRichard Haseltine Posts: 111,390
    It's the actual content in the viewport that seems darker? The viewport colour itself is fairly easy to chnage (Window>Style>Customise Style) and persists between sessions, and reinstallations. Another thing to check, if you have an on0board GPU and a separate video chip, is that the right GPU is still being used for DS (Help>Troubleshooting>About your video card).
  • JQPJQP Posts: 527
    Yeah it's the figures, props, etc. Will check that DS is using right GPU. Was actually wondering if it might be video card driver issue or something. Thanks.
  • cm152335cm152335 Posts: 421
    F2,, check the "PIXEL SHADER" ON/OFF
    with "ON" the viewport show real time your added light on scene (max 8)
    also check "GAMMA" >ON value '2.2'
