Errors with re-installation.
Mynyori
I've had a few crash issues in the past and I decided to reinstall everything on an exterior 2T hardrive. I changed all the installation and application paths in Install Manager. I had to update several items, but they work. But some of my products that worked fine in the past won't even show up. What can I do to fix this or where do I place a manual file?
1360 x 768 - 169K
Did you chnage the paths in DS too? If not, try using http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start which will read the paths from Install Manager and set them as content directories.
That did help. Thanks.
