Genesis bending problem.
Quasar
After installing the latest version of DS 4.5 and the Genesis starter, the thigh doesn't look to be bending right. Has anybody else had this problem? Are there old Genesis files I should have deleted that could be causing problems?
1089 x 871 - 130K
This thread may help: http://www.daz3d.com/forums/discussion/17712/
Thanks for the link. That helped find part of the problem. It is a JCM morph being activated when I bend the left thigh. That same one isn't activated on the right side. However, I can't seems to set the left morph back to zero unless I unlink it from whatever is activating it. The right one remains linked yet doesn't have any problems. I also noticed there is a controller missing from the left one that is in the right one under the controllers tab. ERC[Multiply] > Genesis:Nata is in the right one but not the left.
*EDIT*
Forget that! I found the problem!
Was an old version of Smay's Nata hip morphs!
If you reinstall it from he Download Manager it works fine!
