*Closed* RRRR A long time ago or Far far away Contest
Totte
Welcome to a new installment of the RRRR render contest!
Yes it's time - to fill the summer with the joy of wacky renders. The reason this is starting a little late is that I will be gone, far far away and will be back in mid July, and I wanted to plan a RRRR that won't end while I'm gone.
The theme this round is: A long time ago, or far far away, and it doesn't have to be a galaxy.
How does it work?
Make your pull of 4 items, pull your LBs (Luck Bastards), the current lucky bastard standing is below, and make some great and fun images, it’s not harder than that.
Who can play?
Anyone can play!
How do you prepare yourself for play?
The rules are very simple, but first you need to have all your items in some kind of order in a text file, dumped from the itemized history into a text file or a spread sheet. Remove things like software, gift certs, and special plugins from the list.
Then you use a randomizer to randomly pick items from your list (your Runtime/My Library) for your start pull . You can use items from any store.
Randomizer that works well:
Random Org
Randomizer where you get all numbers in one draw: random
There are some situations where you allowed to redraw, these are:
- You picked something that doesn’t work, broken thing, only works in a version / software not used etc etc.
- You picked a software or add-on to a software or anything you should have filtered out from the list.
- You picked only huge environment props and will not be able to render a scene without crashing.
- You picked an item you already have been using in two RRRR renders in this content and that was picked randomly. Three is a curse - rule!
Lucky Bastard Rule!
If you have sticky lucky bastards, you pull one extra item for each LB you have, simple as that.
Explaination of Lucky Bastards.
Lucky Bastards, or LBs, are a form of handicap system which makes the contest a little more difficult for those who have won.
Current Lucky Bastard standing
| Player | LBs |
| Totte | 3 |
| barbult | 3 |
| Luci45 | 2 |
| Morana | 2 |
| Gopherus | 1 |
How to play?
You pull, you compose and you Render. You post your images and pulls in this thread, but the entry should be posted in the Entries only thread
Bundles
If you pull a bundle, use two three complete items from it, or more if you like, but you do not need to use all, but only picking a hairpin from V4 Complete Bundle is “too little”. Clarification: A bundle still counts as only one pulled item.
Poses, Expressions and textures/colors
If you pull a pose pack, an expression pack or a texture/color pack, you only need to use one of them, not all. For example if you pull 500 expressions for V4, use one, if you pull 128 colors for Frappe Hair, use one.
Accidenty breaking the TOS
If your entry is removed by the forum mods because it accidentally, not deliberate, broke the TOS, you do not have to redo that entry but can move on and make a new pull.
The rules of madness!
Now you have successfully and randomly picked your items, make a scene, you can add other items as well but the one you picked should be prominent or cleverly used. Render it, post it and make us all laugh! Remember though that the renders must follow the TOS of the forum. As we have a theme on the contest, the render should in some way touch that theme.
The contest categories!
There are two categories Best and Funniest. Every image will compete in both categories.
Contest duration!
It starts now at Wednesday June 22 - 2017, and will go on until Sunday August 20 2017 at 23:59:59 local DAZ time.
Yes, we have prizes, thanks to our sponsors!
This months sponsors so far:
Totte is sponsoring with one item in each tier from his store
Dumor3D is sponsoring with one item in each tier from his store.
barbult is sponsoring with a $20 DAZ GC
Karibou is sponsoring with a $20 DAZ GC
More to know?
I will edit this when new info on sponsors arrive.
Do you want to sponsor the RRRR?
Please chip in, sponsors can play, they are even encouraged to play!
Maximum number of entries?
In the contest, the maximum number of enteries are twelve, 12, you heard it, the summer is saved!
Are you ready to render in 3….2….1…..go!
List of some previous RRRR Contests
In the PC Members Only forum:
RRRR Summer Edition ( 13 June 2012 - 15 July 2012) http://www.daz3d.com/forums/discussion/2065/
Winners Thread: http://www.daz3d.com/forums/discussion/5053/
RRRR “Back to Reality / My Summer Memory (15 August 2012 - 23 September 2012) http://www.daz3d.com/forums/discussion/5759/
Winners Thread: http://www.daz3d.com/forums/discussion/9315/
In The Commons: RRRR Commons Premiere (9 October 2012 - 18 November 2012) http://www.daz3d.com/forums/discussion/9325/
Winners Thread: http://www.daz3d.com/forums/discussion/12867/
RRRR “Sayings” Contest (6 December 2012 - 31 December 2012) http://www.daz3d.com/forums/discussion/12867/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/12877/
Winners Thread: http://www.daz3d.com/forums/discussion/15094/
RRRR Contest (18 January 2013 - 24 February 2013) http://www.daz3d.com/forums/discussion/15285/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/15307/
Winners Thread: http://www.daz3d.com/forums/discussion/17908/
RRRR “April Fool” Contest (with “Mini” Contests) (21 March 2013 - 21 April 2013) http://www.daz3d.com/forums/discussion/19109/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/19108/
Winners Thread: http://www.daz3d.com/forums/discussion/21780/
RRRR Summer Contest (23 May 2013 - 4 August 2013) http://www.daz3d.com/forums/discussion/21780/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/22664/
Winners Thread: http://www.daz3d.com/forums/discussion/27864/
RRRR “Chain” Render Contest (15 September 2013 - 13 October 2013) http://www.daz3d.com/forums/discussion/27864/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/28997/
Winners Thread: http://www.daz3d.com/forums/discussion/31526/
RRRR “Chain” Render Contest - Round II (1 November 2013 - 1 December 2013) http://www.daz3d.com/forums/discussion/31615/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/31760/
Winners Thread: http://www.daz3d.com/forums/discussion/33417/
RRRR “Story” Contest (4 December 2013 - 12 January 2014) http://www.daz3d.com/forums/discussion/33479/
Entries-Only Thread: http://www.daz3d.com/forums/discussion/33478/
Thread: http://www.daz3d.com/forums/discussion/36407/
RRRR - One day in XXXs life Render Contest: 13 February 2014 - 16 Mars 2014) http://www.daz3d.com/forums/discussion/37042/
Entries only thread: http://www.daz3d.com/forums/discussion/37041/
Winners thread: http://www.daz3d.com/forums/discussion/39504/
RRRR Classic (19 May 2014 - 22 June 2014) http://www.daz3d.com/forums/discussion/41451/
Entries only/Winners; http://www.daz3d.com/forums/discussion/9325/
RRRR Freak Accindents (15 July 2014 - 10 August 2014) http://www.daz3d.com/forums/discussion/43832/
Entries only/Winners: http://www.daz3d.com/forums/discussion/43830/
RRRR Back to renders ( 25 Aug 2014 - 28 September 2014) http://www.daz3d.com/forums/discussion/45619/
Entries only/Winners: http://www.daz3d.com/forums/discussion/45617/
RRRR Things to do before you die ( 13 October 2014 - November 9 2014) http://www.daz3d.com/forums/discussion/47518/
Entries only/Winners: http://www.daz3d.com/forums/discussion/47517/
RRRR Unleashed (3 December 2014 - 11 January 2015) http://www.daz3d.com/forums/discussion/49497/
Entries only/Winners: http://www.daz3d.com/forums/discussion/49496/
RRRR Not on the screen ( 29 January 2015 - 1 March 2015) http://www.daz3d.com/forums/discussion/52007/
Entries only: http://www.daz3d.com/forums/discussion/52006/
Voting & winners: http://www.daz3d.com/forums/discussion/53400/
RRRR Just Random (25 March 2015 - 3 May 2015) http://www.daz3d.com/forums/discussion/54371/
Entries only thread and Winners: http://www.daz3d.com/forums/discussion/54370/
RRRR Unlikely Occupations (20 Jun 2015 - 2 August 2015 ) http://www.daz3d.com/forums/discussion/56841/contest-rrrr-unlikely-occupations-with-prizes
Entries only thread:http://www.daz3d.com/forums/discussion/56835/
Winners thread:http://www.daz3d.com/forums/discussion/61494/rrrr-unlikely-occupations-winners-announced
RRRR Stupid is as stupid does (September 1 2015 - October 4 2015) http://www.daz3d.com/forums/discussion/61970/rrrr-stupid-is-as-stupid-does-render-contest-closed/
Entries thread: http://www.daz3d.com/forums/discussion/61969/rrrr-stupid-is-as-stupid-does-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/64971/rrrr-stupid-is-as-stupid-does-winners-announced
RRRR Murphy's Law (November 15 2015 - Sunday January 10 2016) http://www.daz3d.com/forums/discussion/66026/rrrr-murphy-s-law-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/66025/rrrr-murphy-s-law-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/70820/rrrr-murphy-winners-announced
RRRR The sequel ( February 11 2016 to Sunday March 20 2016) http://www.daz3d.com/forums/discussion/71563/rrrr-the-sequel-render-contest-closed/
Entries Thread: http://www.daz3d.com/forums/discussion/71562/rrrr-the-sequel-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/78321/rrrr-sequels-winners-announced
RRRR Story ( April 8 2016 to Sunday May 15 2016) http://www.daz3d.com/forums/discussion/78671/closed-rrrr-story-render-contest/p1
Entries Thread: http://www.daz3d.com/forums/discussion/78666/rrrr-story-contest-entries-only-thread
Winners thread: http://www.daz3d.com/forums/discussion/92406/rrrr-story-winners-announced
RRRR Twisted Lyrics (June 7 2016 to July 31 2016) http://www.daz3d.com/forums/discussion/92481/rrrr-twisted-lyrics-contest
Entries Thread: http://www.daz3d.com/forums/discussion/92471/rrrr-twisted-lyrics-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/108966/rrrr-twisted-lyrics-winners-announced
RRRR What does it mean (September 11 2016 to October 30 2016) http://www.daz3d.com/forums/discussion/112771/rrrr-what-does-it-mean-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/112766/rrrr-what-does-it-mean-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/127361/rrrr-what-does-it-mean-winners-announced
RRRR Alternative Holidays Render Contest (November 17 2016 to January 15 2017) http://www.daz3d.com/forums/discussion/127526/closed-rrrr-alternative-holidays-render-contest
Entries Thread: http://www.daz3d.com/forums/discussion/127521/rrrr-alternate-holidays-entries-only-thread
Winners Thread: http://www.daz3d.com/forums/discussion/147326/rrrr-alternative-holidays-winners-announced
RRRR - It could be true - 5th anniversary contest: https://www.daz3d.com/forums/discussion/149891/rrrr-it-could-be-true-5th-anniversary-contest
Entries Thread: https://www.daz3d.com/forums/discussion/149886/rrrr-it-could-be-true-entries-only-thread
Winners Thread: https://www.daz3d.com/forums/discussion/167426/rrrr-it-could-be-true-winners-announced
Enjoy a rainy and windy summer!
Yay, Totte!!!!!!!!!!!!!!!! I'm so very happy to see this!
Have a great time doing your summer things. Your LBs will be waiting for you.
Pull #1:
Family Night for Family Car 1950
Strapless Intimates Collection
Trinity Atrium
A Curious Hallway
Raysee Doll (LB)
Elven Dress for Genesis (LB)
I've been looking forward to this with a sense of excitement and dread knowing those LB's would be waiting for me. lol I need to update my product spreadsheet since I've been shopping the last couple of months.
Been a while since I participated. Great theme. I'm in this one.
I will try to do an entry using Daz Studio. Here is my first draw.
2674 3373 1285 2502
Random numbers generated Jun 23 2017 at 10:13:22 by www.psychicscience.org
Free educational resources for parapsychology and psychical research.
2674 Glamorous Aiko Set for Aiko 3,"4285","2013-02-14T20:24:27Z"
3373 Laid Back Outfit for Genesis 3 Male(s),"23331","2015-11-13T16:38:05Z"
1285 Creature Creator Add-ons For Genesis 2 Male(s),"19399","2014-07-11T06:34:38Z"
2502 FWSA Riva,"18338","2014-02-11T15:48:38Z"
Nice to see Luci (couldn't keep you away from RRRR using a trumpwall), Morana (anotherone got hooked) & Diomede (long time no see)
And here's the list for #1:
A real mix of genres and items in there, I like it! Though it's funny I used Hazard Zone as a backdrop filler in one of my entries last round, and this time I actually pulled it.
It's alive! IT's ALIVE!!
Summertime is a lot of There and Back Again s. Glad that the contest runs all the way through the great eclipse of august
And looking forward to wind and rain to cool off the hot and hotter
Draw #1
Under the Bridge
Savage Freak 5
Immortal Dream Hair
Preppy Hairstyle
Winter Ice Render Studio 2014 LB
No, not even a trumpwall, Totte! Welcome back, Diomede! And Morana (I bought a lot of stuff since the last RRRR too, couldn't believe it.)
Yea, Gopherus! I don't know when the wind and rain comes for us in SoCal, but we know the hot and hotter has arrived. Ouch.
tag:luci45 #1
The First and Last of the Urban Elves
Long ago and far away elves tried to be urban dwellers, but it didn't last and they soon returned to the forests. Raycee and Lance fondly remember their teenage dates when Ryacee's mom used to scream at her, "Get back in here and put some clothes on and wipe that s*** off your face! You are a disgrace to efldom!"
Used:
Trinity Atrium
A Curious Hallway
Raysee Doll
Also used:
Girls Night Outfit
Shaders
Esidor Hair
Elements Hair
Kami Hair
Yakuza Outfit
Teen Josie
Teen Jayden
Lance
iRadiance - HDRI Variety Pack Two
Pull #2:
Princess of Summer
Bath Wear for Genesis 2 Male(s)
Tre Textures
The Mage
Toxic (LB)
Rons Sci-Fi Optical Flares (LB)
Great opener! Love the reflections!
Maybe the mom is afraid that the family car will give the 2 kids too many ideas.
and maybe she has memories of all her times in the back seat.
tag: luci45 #2
The Alchemist and His Apprentices
A very long time ago alchemist Zorb Tchichink, with the aid of three strnge little men(?), discovered many secrets about energy conversion. They have been lost, unfortunately, because he failed to write them down. Some said there were indeed journals, but that they disappeared when the mysterioius threesome returned to wherever they came from.
Used:
Princess of Summer
Tre Textures
The Mage
Toxic (LB)
Also used:
Opus Magnum
MICK
Creature Creator Genesis
Dwarfology
Lizardians
IDG Iray FX
JoLab Liquid Pack
Nosferatu
Aging Morphs G3M
Alatar
Santa Beard
Heath hair
Anjou Hair
Opal
TnC Boots
Royal Elf Boots
Kilt Boots
Luci45 Tag #1 wow loving your first render what a great way to start of this round of RRRR with some cute elves!!!
Tag#2 Very magical things going on in this render 2 thumbs up for that one!!!
Now I just can't wait to see what everyone else comes up with this round!!
I may just find time to do a couple of pulls yet.
Jumping in! Seems like a great (and fun) way to get back in sync with what's actually IN my library after three years away. The stuff since I came back is easy... but those old files are Theseus' Labyrinth atm.
Dumped the list from my Daz and Rendo purchases so it's not 100% but should be most of it. Couldn't think of an easy way to dump info re freebies and stuff from other sites.
459: Edwardian Hair for Genesis and Genesis 2 Females
1110: Props Pack - Fantasy Banquet Set
341: Dark Priest Poses for M5
789: Kamal
Fairly straightforward set for the warm up it seems, RNJesus is going easy on me.
Wow, Luci45, two fantastic renders! Should we be worried about what the elf might be mixing up in that toxic barrel? hehe
Welcome, CharcoalWarden! This contest is a great way to dig up gems from your library. I found the shot of inspiration and creativity to be... addictive. :)
I'm in!
@Luci45 #2 Love the lighting effects! Zorb would certainly have been a hit in Hobbiton for their country fairs... that is if
Gandolf hadn t locked up the franchise.
Wow, I'm glad to see some more participation!
Welcome, CharcoalWarden! You will probably have a lot of fun with the RRRR. That's what it's for.
Thanks, Gopherus, Saphirewild and Morana.
Wow, barbult, 3 LBs!
Pull #3:
Creatures of the deep
Street Rogue Outfit for Genesis 2 Male(s)
Derelict Barn II - Poser
Polearms
Buddha Statues (LB)
Kingdom of Marrakesh 2012 (LB)
Tag: Morana #1
Hazardous Secrets
Somewhere... buried in the depths of time. In a castle... on a path no one ever climbs... a man keeps a toxic waste dump. Within it are barrels of vile liquids, and crates full of unspeakable things. There's a cosplayer who he thought really was the winter queen, until he realized she wasn't and banished her to his horrible holdings in a fit of pique. And there's the space elf ex-girlfriend who wouldn't stay out of his business. She continues her quest to find the key to his undoing among his discarded secrets. And then he'll really get a piece of her mind.
tag: luci45#3
In a Far Away Marketplace
Used:
Polearms
Buddha Statues (LB)
That has great atmosphere!
Very mysterious, a little creepy, and what a great story!
@morana #1 dumping his women in the same place with his vile wastes will definitely result in unexpected blowback. what was he thinking? it hints to me also of a scene from kurasawa s yojimbo/ leone s fist full of dollars.... who will dare go into the basement? good one!
@luci45 #3 ah!! a night time market place to escape the heat of day with good eats and probably a live band around the corner. i almost expect to see jackie chan ordering at one of the food stands.... wish i was there. well done!
Thanks for the comments! I had so many issues creatively and technically it was driving me bananas. Onto the next one, and no gowns this time, yay!!
Pull# 2
Thanks, barbult and Gopherus!
Nice render and story, Morana! Very mysterious. Don't forget to post it in "Entries Only" thread.
Pull #4:
Street Rogue Outfit Textures
Beach Vibes Outfit for Genesis 3 Male(s)
Karaoke Machine
Moonshine's Diner Interior III
Provence (LB)
Eva 7 (LB)
I’m back from my sons Wedding in far far way land.
Lucy #1: Superb render and a funny story, great start!
Lucy #2: Very Luci-esque, vivid colors, great render, simply wow!
Morana #1: Very nice render and fun story, toxic waste dump, what can possible go wrong?
Lucy #3: That looks just like the over a half mile long Chiang Rai night basar, where you could by roasted grasshoppers or larvas by the shot glass, and one million other strange things, love it!
Now I just need to get some time to render some of the weird things I’ve seen, like the mummified monk with sun glasses, I think that’s the top weird thing.
Welcome back, Totte! I look forward to your weird renders. I have one entry rendered, but haven't worked out exactly what the story is.
Meanwhile, sign me up for $20 sponsorship again, please.
Yay, Totte's back! I look forward to some even-stranger-than-usual renders.
Thanks for the appreciation. I had fun with them.
I'm BAAAACK!!! I have to update my library database (haven't done so since December, though I also haven't really shopped since December either!) I MISSED YOU GUYS!!
Oh, and put me in for my $20 GC prize pool donation.
