Saving a vertex selection script?
Been trying to save selected vertices for using in creating morphs for use later. However the scene file does not retain the selection. Is there a way of creating a pose or script that can reselect the vertices I want without having to go through the entire selection of different areas every time?
Post edited by darren_dd9be07039 on
  • Richard HaseltineRichard Haseltine Posts: 111,864
    I'm not sure. A non-script approach would be to select your vertices, right-click, Geometry Assignment>Create Selection Set from Selected... The Selection Set should save, you can then reselect the vertices by clicking the + next to its name in the Tool Settings pane with the Geometry Selection tool active.
  • Thank you I will give this a try.
