Victoria 8 problem
Is there anyone else out there having problems with Victoria 8. I purchased the Pro bundle did a manual install,daz connect Install, and Daz download manager install. The figure is coming up as grey blocks. The clothing and such seem to load fine on thier own.
«13
    did you remember to also install the Genesis 8 starter essentials?
  • does that come with the pro bundle?
    edited June 2017
    no it should be in DIM.  It contains the free genesis 8 female figure which you need to get V8 working, in the same way as you need Genesis 3 to get V and M 7 working
    Post edited by Chohole on
  • Let me look into that thank you
  • frank0314frank0314 Posts: 14,804
    edited June 2017
    You need to install all the Starter Essentials packs to get the various versions to work. If using DIM just do a search for "Starter" and the same if you install manually in your content library.
    Post edited by frank0314 on
  • Nope still not working
  • Same problem here all files installed V8 not loading
    Ok,  let's approach this a different way.   Have you installed the latest update to Daz Studio?    https://www.daz3d.com/forums/discussion/175016/daz-studio-4-9-4-pro-general-release/p1
    Did you install manually or with DIM?
    Try uninstalling all 3 V8 you installed and install only one and see if that helps. May be conflicting but I'm not sure. We are just trying to troubleshoot.
  • Tried both manuall and DIm installs also uninstall and reinstalled all V8 files
  • Latest version of Daz installed
  • I think the problem may be on Daz's end and an update is in order.
  • TenguTengu Posts: 416
    I've  had the same problem.  G8F has no thumbnails and won't load, and V8 loads as grey blocks.
    Tried installing/uninstalling/installing through Connect and DIM and cleared content database.
    Here is the error shown when failing to load base G8F:
    2017-06-15 18:22:35.289 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-06-15 18:22:44.373 WARNING: No DzApp instance could be found in DzCLDatabaseMaintenanceAction::executeAction()
    2017-06-15 18:22:44.373 WARNING: No DzAssetMgr instance could be found in DzCLDatabaseMaintenanceAction::executeAction()
    2017-06-15 18:23:15.956 WARNING: general\dzcontentmgr.cpp(3743): Empty relativePath passed to DzContentMgr::getAbsolutePath()
    2017-06-15 18:24:07.526 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-06-15 18:24:58.858     C:/Users/*****/OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_42071/people/genesis 8 female/genesis 8 basic female.duf (1,1): Syntax error - expected '{' or '['
    2017-06-15 18:24:58.858 Error reading file, see log for more details.
  • Daz quality control strikes again... Glad I'm not the only one. I liked the old days where everything was in a zip file.
    If it was a problem on DAZ's end everyone would be having problems.
  • So yours loaded up fine?
  • the basic wear doesn't load either FYI
    Yes Genesis 8 is working just fine for me.
    Has anyone thought to put in a tech support ticket? This issue isn't happening for everyone so its something on the user end.
  • I put a ticket in all I got so far was did you install the essentials
  • edited June 2017
    Lucky
    edited June 2017
    I fixed your post. It was accidently added to the quote.
  • Well thank you Frank.
  • sfaa69sfaa69 Posts: 353
    Maybe the versions installed have different results. I installed the Win64 version and get the grey blocks for V8 and no way to load G8.
    Which version worked for you?
  • markgoode77markgoode77 Posts: 343
    Grey blocks here too.  V8 Pro pack, verything installed by DIM.
    I'm going to remove it and try again.
  • Same issue here!
  • Richard HaseltineRichard Haseltine Posts: 109,791
    So, which version are you currently using - DIM or Connect? If you have both, Connect will be used.
