Runtime Repair 1.11 vs 1.24 (Solved)
Charlie JudgeCharlie Judge Posts: 13,651
edited June 2017 in The Commons
I found a copy of D3D's Runtime Repair in the downloads saved from my old computer. It is version 1.11 and I notice the current version is 1.24. Is there a a significant difference between these two versions to justify the $16 purchase cost of the newer version?
( It looks like I got it in 2008 but I can't find my old purchase records for it in order to request an update)
Post edited by Charlie Judge on
  • TaozTaoz Posts: 10,368
    Where did you purchase it?
  • Charlie JudgeCharlie Judge Posts: 13,651
    edited June 2017
    I'm not sure. I got it a long time ago maybe in 2008 and from the looks of the license file it may have been Content Paradise, but I can't find a record of the purchase there.
    No, purchase records from the old CP store (before 2008-2009) are no longer available there, AFAIK.
    Thanks. That may also explain why I couldn't find purchase records for a couple of Vanishing Point items (Eagle Lander and Blossum Hill Mill) that I have..
    However, it doesn't answer the question of whether there are signifidcant changes to justify purchase of the later edition. Does anybody have any insights?
    Thanks,
    Charlie
    I just checked, it's actually included with the Power Tools bundle I purchased at Rendo once. There is a history file in the zip, I guess it contains what you're looking for.
    Runtime Repair
    Version History
    09. Oct 2006
    Version 1.0
    Initial release.
    28. Dec 2006
    Version 1.01
    Bugfixes:
    - fix material offset: crash when file name was missing
    - wrong dialog, if no runtime was found on start up
    - preserve file attributes when (de)compressing geometry files
    Changes:
    - added Poser 7 to change Poser version
    - find multiple Runtimes settings for Poser 7
    - ignore "NO_MAP" as file in shader trees
    06. Jan 2008
    Version 1.1
    Bugfixes:
    - file references tool: path to Python scripts was replaced by wrong path if not found
    Changes:
    - new task: remove invalid double quotes
    - new task: remove double spaces
    - new task: set image filtering type in shader trees
    - options: shader tree settings for Poser version and bump strength
    - correct file path: also corrects missing NO_MAP and some irregular uses of it
    - summary: buttons to open log files in text editor
    - file references details: manually add files or no file for replacement
    Changes (File References):
    - added soundFile and movieFile
    - cancel-dialog during file search
    24. May 2008
    Version 1.11
    Bugfixes:
    - possible crash if quotes are missing aroung Image_Source in shader tree
    - wrong replacement for files with spaces when quotes are missing
    18. Aug 2009
    Version 1.2
    Changes:
    - own dialog for Runtimes
    - remember last folders
    - file reference dialog: add file to all references with the same file name
    - option: shader tree for P7 Pro / P8
    - option: file NO_MAP instead of file "" in shader trees
    Bugfixes (File References):
    - move file now works for multiple files
    - cancel dialog for search files lists found files
    - open/explore/copy file path
    - Python files no longer force absolute path if not in main Runtime
    - file NO_MAP instead of file "" in shader trees
    - allow deleting obj for figure/prop
    29. Sep 2009
    Version 1.21
    Bugfix (Runtime Repair and File References):
    - Runtime folders added by "Add Runtime folder..." did not work
    Changes (Runtime Repair and File References):
    - add Runtime folders by drag'n'drop
    - show Runtime folders included in LibraryPrefs.xml
    02. Jan 2012
    Version 1.22
    Changes (Runtime Repair):
    - Poser 9: version number, crisp image filter, runtime dialog
    - ignore PNG thumbnails when searching for image files
    - Poser 9: runtime dialog
    21. May 2013
    Version 1.23
    Bugfix (Runtime Repair):
    - possible crash for files with long lists
    - Poser 10: version number, runtime dialog
    09. Feb 2016
    Version 1.24
    - no more colon in front of GetStringRes when creating shader trees
    Thanks. Yes, that is what I was looking for. I'll have to think about whether or not I want to buy the updated version.
  • pwiecekpwiecek Posts: 1,598
    I had a problem with RR taking PMD references and switching them to PNG. I contacted D3D and he got me a free fix. Unfortunately, I believe he is no longer available.
