background
Thadeus72Thadeus72 Posts: 415
hi
when i use a background for my render (like this http://www.daz3d.com/magic-backgrounds for example) it render well and when i save the picture , the background is white :shut:...
i use the last version of ds 4.5.. on windows 7 64 bit
thanks in advance
  • wancowwancow Posts: 2,708
    are you saving to PNG? If so, you're saving with an alpha channel. I'm not sure if it preserves the background or not, but the easy work around is to save to JPG.
  • Thadeus72Thadeus72 Posts: 415
    i saving to tif , i d like to work them in lightroom
    thanks for your help
    If you're saving to .tif then you get exactly the same alpha channel that you get saving to .png — both of them will tend to not show a background pic that isn't actually part of the scene.
    What are you using to look at your saved renders? There are ways to "flatten" the image to make the alpha channel visible.
