Log File
allanon
Is there a working aid or manual somewhere that demystifies the log file to make it understandable?
Post edited by Chohole on
allanon
Not really, but you can ask about any bits you need to understand and with luck soemone will be able to explain.
Okey dokes. I posted in another thread the log file showing what happens when I load a certain model. It refers to an incorrect sRGB profile.
The only part I teally undersand are the calls to the texture files, which are correct. Unfortunately, the log file doesn't refer to line numbers in the CR2. The full portion from the logfile is attach3ed here.
It's better to keep the related questions in one place. I thought I'd said that the profile message was unlikely to be an issue - a lot of PNGs (maybe even all) give it.
