converting geograft to regular conforming item inside DS?
MistaraMistara Posts: 38,675
converting geograft to regular conforming item from DS menus?
i've been doing it manually by editing the dsf file in text editor.
surely there is an easier way inside DS?
any tips appreciated, thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,743
    Not that I know. You can change the AutoHide group to a single polygon, but it's still a GeoGraft
    okay, thanks!
    been trying to figure this out last 3 months
  • DaWaterRatDaWaterRat Posts: 2,887
    edited June 2017
    Okay, there's some clothing I've gotten that appears to be Geograft based on behavior, and I have managed to un-geograft it.
    Load in two copies of the item you're trying to de-geograft.
    With one of them, convert figure to Prop (it's on the Scene tab options drop-down, under Geometry)
    Parent the prop to the other copy
    Now convert Prop to Figure, and select inherit skeleton from parent.
    Now re-name your item and save it somewhere else.
    I've done this all of twice, so I might be missing a reason why you wouldn't want to do this, but it has resulted in being able to, for example, turn off sleeve textures on a geo-grafted top so I could make it short sleeved.
    Also in both cases where I've done this, the clothing item had no apreciable morphs.  If they do, there's probably a few steps with morph transfer you'll want to add in there.
    Post edited by DaWaterRat on
    thanks smiley  oh the agony of it all.
    one more weekend of my life, only cause it's so difficult to give up on a project.
    after that C'est la vie, eso es la vida, takie jest życie, che è la vita, Das ist Leben, それが人生, zhè jiù shì shēng huó, yIn ghaH
