Skool Daze Error
I used the DAZ Install Manager to install this and the following comes up when you click on the DS Scene File !PSH Classroom:
Some assets needed to load the file were missing. The content may not work as expected. The following files could not be found.
/data/Jack Tomalin/PHR/PHR_Chlkbrd/phrec_chlkbrd_10158.dsf
/data/Jack Tomalin/PHR/PHR_Vic_Desk/phrec_vic_desk_2959.dsf
/data/Jack Tomalin/PHR/PHR_Whitebrd/phrec_whitebrd_48.dsf
/data/Jack Tomalin/PHR/PHR_Dsk_Chair/phrec_dsk_chair_3533.dsf
/data/Jack Tomalin/PHR/PHR_Chair/phrec_chair_2682.dsf
/data/Jack Tomalin/PHR/PHR_Bkshelf/phrec_bkshelf_188.dsf
/data/Jack Tomalin/PHR/PHR_Desk_Sq/phrec_desk_sq_728.dsf
/data/Jack Tomalin/PHR/PHR_Desk_Lng/phrec_desk_lng_728.dsf
Every item in the scene file seems to have the same problem and there isn't a PHR folder under that path. I did a search for the dsf files and that also came up blank. I even downloaded and installed the Poser files just to see if that was the problem. That did not correct the issue. Anyone experiencing the same issues with the DS files?
  • Dr StupidDr Stupid Posts: 313
    Those look like the geometry files from the Parkside High Recess product. You need that installed for the Skool Daze textures to work.
  • Richard HaseltineRichard Haseltine Posts: 112,316
    You may need to reset Park High Recess and reinstall the DS version to get those files - they won't be in the Poser version, and they may not have been in the original DS version depending on which format it used for its scene files.
  • edited December 1969
    Hey thanks, I redownloaded the Recess file and that took care of it. I must have overlooked that on the original install. It's been kinda confusing figuring out which products need both the poser and ds installer and which ones work with just the ds installer.
