Replicating?
If I have an item in the scene, is there anyway to copy that item (I mean so I will now have two of the same item) in the same scene? Right now, if I have a charcater that I have done a ton of morphs and changes to, I will save the character into a temp file and then bring it back into the scene using merge. Is there a simpler way? I'm using Daz 3.1 for now..Is it okay to ask D3 questions here? (I'm going to upgrade this summer but need help now!)
DS3 does not support that feature. The method your using is the best way to do it. I use that method in DS3A myself.
Would this product be of any use to you? : http://www.daz3d.com/send-in-the-clones
There is also a DS4 version: http://www.daz3d.com/send-in-the-clones-ds4
as well as pro versions of the above 2
Hope that helps :)
Bella :)
