Duplicate formula error
Hi,
I need help tracking down which file is causing this duplicate formula error
WARNING: fileinput\dzassetdaz.cpp(5136): Duplicate formula found linking ZBulgeNegRight & Value in /Scenes/NNNNCharacter.duf
I'm getting it for a whole bunch of scene files and I can't figure out what's causing it.
Tried all the install/uninstall advice and I'm getting nowhere.
Thanks.
Have a look at this in the Knowledge base:
https://helpdaz.zendesk.com/entries/20651678-How-to-fix-the-Duplicate-Formula-message
What version of DS are you using? Help > About DAZ Studio
Are you finding these in the Log File? Help > Troubleshooting > View Log File?
Does the content work correctly when loaded? These are warnings rather than errors, but they should be able to be fixed.
So this will be really easy - Everything I have is no older then October 2012.
I'm using the newest version of Daz and tried uninstalling everything on the list and then some.
I had things installed and started uninstalling them peice-meal when the Content manager came online - so that I could let the content manager install things into one spot.
I think what happened might be that the content manager isn't installing something correctly now. Since the problem started coming up Wed night-Thursday. It's really recent.
If I could track down which file in specific was causing the problem, I'd re-install it using the old installer... but I can't figure out which product is the culprit, and I really don't want two copies of a bunch of programs on my computer if all I need is one. It's the same error for a whole bunch of my personal scene files.... which to me says it's only one file set causing the problem.
PS:
DAZ 4.5 pro
Yes the problem is copied from the log file... which is very long and throwing a huge bunch of repeats of the same error (and why I didn't copy the whole file.
But it comes up when the content is loaded.
It also shows up as a formula duplicated error when I load the file.
The files take a while but they do eventually load and nothing seems to be amiss.
