This texture for this product?
Can I use these textures https://www.daz3d.com/nord-spring for this product https://www.daz3d.com/sighni-outfit-for-genesis-3-females?
It says it's for the G2F one and not the G3F one, but I only have the G3F version... Would like to know if it's the same UV :)
    According to the What's Included & Features section of the G3F version of the dress:
    • Textures for previous versions are compatible with this one, as mapping has been retained
    So, I'd say yes, they're compatible. :)
  • Richard HaseltineRichard Haseltine Posts: 111,157
    Yes, I have used it that way. You may get an alert from DS since it thinks that the item goes on the g2F version (I didn't have it isntalled, if you do that might block the alert) but if you do just cancel it and the textures will load (I think that was a set where I converted the displacement map to a normal map, however, to avoid needing a high SubD level).
  • CherubitCherubit Posts: 995
    Thanks for the answer! :D I'm glad to know it works!
