Remove script from script drop down?
BruganBrugan Posts: 365
Answer is probably obvious but I'm not seeing it. How do you remove a script from the script menu bar drop down if you no longer need it/want it in the list?
  • NorthOf45NorthOf45 Posts: 5,950
    From the menu, select Window > Workspace > Customize (or hit F3) to get the Customize popup.
    On the right side, click on the Menus tab and expand the "Main Menu" entry, then expand "&Scripts" to see your custom actions.
    Right click the undesired item and select "Remove Item".
    All done.
  • BruganBrugan Posts: 365
    Awesome, thanks for the reply :)
  • Richard HaseltineRichard Haseltine Posts: 112,346
    You can also remove the action entirely from the Custom group on the left of the dialogue, if that's your aim.
    Thanks Richard!
