Resuming Render
It's beyond me why I can't find this simple question by Googling or looking in the Daz Forums. Is there anyway to resume a render after the Cancel/Resume window is closed out?
Thank you
  • ToborTobor Posts: 2,300
    edited May 2017
    Ooops! On edit, I see you said with the "window is closed out."
    Sorry, the answer to that is no. Iray and D|S don't offer this feature.
    For lurkers and other interested parties, in those cases where the window has not yet been closed:
    Try opening the side panel of the window on the left (look for the little "thumb" bar there to expand it). Choose Progressive Render, and change any/all of the stop-at values to increase the render time. If, for example, the render stopped because you reached 5000 iterations, increase the Samples. If it reached the convergence ratio, and you've already set it at 99%, you can try increasing the Render Quality from its default 1 to a higher number (2 is a good starting option).
    Post edited by Tobor on
  • gederixgederix Posts: 392
    Theres ways to do what you want but not with 3delight or iray.
