Ghost Shaders
I ave been using a product called PW Ghost, and found it is only available in 3Delight, I was wondering if it would be possible to convert it into IRay, and if so, how would I go about it?
  • Richard HaseltineRichard Haseltine Posts: 112,346
    For Iray the simplest solution is probably two renders, and layer them in an editor. You might be able to use Canvasses and Light path Expressions to get the effect, but that would be fiddly. Iray doesn't lend itself to the sort of stylised effects that 3Delight supports.
  • For Iray the simplest solution is probably two renders, and layer them in an editor. You might be able to use Canvasses and Light path Expressions to get the effect, but that would be fiddly. Iray doesn't lend itself to the sort of stylised effects that 3Delight supports.
    Thank you, haven't yet worked with the layer editor, Must do so.
  • Though, I must admit to the temptation to try to do it. As then I could create a great shader for slime girls....Suu for the WIN!
  • Was messing around this morning and had completely forgotten the Vengful Spirit that I had purchased a While back, and though I am currently in a render in Iray, everything looks good so far. If it works out well, I will mess around with the settings and see what kind of effects I can come up with. Thank you for the advice Richard, it is much appreciated. Even though I have been using Daz for a while now, there is still so much that I need to learn.
