Import object size
Hello
I have been experimenting with different types of object imports into Carrara. One odd thing is often I import an object ( different file formats) and I see a large "Box" of where the object should be.
Now I've had some sucess with obj, 3ds, and FBX. But often I get an object with crazy huge NEGATIVE number for size. Even if I increase the size I don't see it.
I have had no luck importing DXF, and can't seem to get eps to work in spline model room. Any tips?
Thank you
8068
Any problem to import .obj and .3DS but .fbx never work for me (a"large box",like you), it is on my scene but I can't see it.
Never tried .DXF.
The FBX import in Carrara is from the times before they invented the wheel so don't expect it to work with anything but very simple stuff (square things ;)
