Performance behavior with CPU / GPU / CPU + GPU as expected?
uezi
Hi,
I've just migrated from a Mac to a Windows PC and for the first time, I've got a nVidia GPU. Now I got some questions on the observed performance...
Specs: Intel Xeon with 4 cores, 8 threads, 32 GB memory, Quadro M4000 (8 GB)
Scene: 1080p with 5 G3F/G3M figures, clothes, hairs, Props, Tavern, Background, lights, iray
ray Memory Assistant reports: 18 GB SysMemory, 4 GB VRAM
| Rendering method | Duration |
| CPU only | 6h 01min 01s |
| GPU only | 1h 48min 41s |
| GPU + CPU | 1h 26min 23s |
| GPU + CPU + Optix enabled | 1h 21min 35s |
Is this somehow expected ?
Adding a GPU "only" gives a performance boost of ~4.5x ?
Thanks & best regards,
Peter
Hmm, that card only has 1664 cudas. Also, I tend to run a config you don't have listed, i.e., GPU + Optix (no CPU).
To see if you're getting decent performance, you should run the scene in this thread:
https://direct.daz3d.com/forums/discussion/53771/iray-starter-scene-post-your-benchmarks/p1
Then simply peruse a few of the posts to see how yours compares with others.
These numbers are in line, though it really depends on the specific hardware. The M4000 uses an earlier generation of CUDA cores, so you'd probably get a little better performance if you used one of the Pascal-based cards. Xeons run the gamut between pretty fast to dog slow; my current dual Xeon system is only slightly faster than my older single Xeon system, though it has four more cores.
You will note that there's only a 15-20 minute advantage between GPU and GPU/CPU, so you may elect to just use the GPU, freeing your computer during your render. I burned out my previous Xeon workstation because of very long renders. Even Xeons aren't made to be full throttle at 100%.
