Figure clone problem
I am trying to make a custom character for Micheal 3 specifically Roronoa Zoro from One Piece. I made a Genesis 2 Clone for Michael 3 due to G2M having the hair I needed. I followed the tutorial for cloning V4 for Dawn PDF attached. I followed it all the way up to where it says load morph via Morph Loader Pro. I did so and I see no morph preset in my parameters tab like it said there would be. I checked all drop down menus. I scrolled through and still didn't see it. Now I learned that DAZ has separated the property editor into two parts for faster loading. So I also checked part two which is the property hierarchy. I scrolled through all the options there and still didn't find it so I can properly add the morph to my figure.
Not exactly sure what I am doing wrong as I followed all the steps up to that point perfectly.
  • Richard HaseltineRichard Haseltine Posts: 112,066
    The path under which a morph will appear, assuming it loaded without errors, is set in the Morph Loader Pro options (click the triangle next to the file name).
    I've removed your attachment as the tutorial was not yours to redistribute - if you want to indicate what tutorial you are using please link to the source page or forum thread..
  • It was not my intent to redistribute. And I got the tutorial from Hivewire community forums. Can't recall which post for a link. Well, I'm still not having any luck. I even tried GenX. Not even that is working. And DAZ crashes when I try the asset transfer. It won't even transfer M3 assets. I am really annoyed and at my wits end. I know it can be done. But it seems nothing is going my way. Looks like I really picked a lost cause.
    I'm a little confused as to what you are trying to do - Michael 3 is an old, parametric rigged figure and so can't be used as the destination for AutoFit, nor can it be the source for Transfer utility. Are you trying to go from Genesis 2 Male to Michael 3 or vice versa?
  • I was trying to make a clone of M3 for G2M so I could use M3 morphs on G2M. Well, I more or less solved my problem. Took me three days to realize that the hair's original parent path was the G2M's hip...... Gah......I am way outta practice. So I pointed it to the head and now M3 can wear G2M hair. So as the picture shows, I am now able to use the hair normally. Sorry for the trouble. I is a doofus.
    477 x 609 - 391K
