Error message: Duplicate Formulas Found
I just manually installed the ESS Euni character (Renderosity) into DAZ Studio 4.9 and when I loaded a character I got an error message as shown in the attached image.
The relevant section of the log file says:
2017-04-30 10:32:30.579 WARNING: fileinput\dzassetdaz.cpp(5846): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis 3/Female/Morphs/ESS/ESS Euni Head/ESS Euni Head.dsf.
2017-04-30 10:32:30.598 WARNING: fileinput\dzassetdaz.cpp(5846): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis 3/Female/Morphs/ESS/ESS Euni Head/ESS Euni Head.dsf.
Can anyone tell me why this error has occured and what I can do about it?
506 x 105 - 18K
  • Richard HaseltineRichard Haseltine Posts: 112,346
    First make sure that you didn't end up with two copies of /data/DAZ 3D/Genesis 3/Female/Morphs/ESS/ESS Euni Head/ESS Euni Head.dsf in different content directories.
  • IsaacNewtonIsaacNewton Posts: 1,300
    Hi Richard, I checked the whole Content folder structure I use for DAZ3d products and G3f products like Euni and the ESS Euni Head.dsf  appears only once.
    You may need to contact the vendor at Renderosity - it may be a product bug.
    I'll try that, thanks.
  • mindsongmindsong Posts: 1,796
    Richard - do you know if this message/issue actually does any damage to the scene or render, or is it simply bothersome?
    (I always try to 'fix' the issue, but also always wonder if it matters...)
    tnx,
    --ms
    I'm not sure - I think DS either uses the first or the last formula and discards others but that may well be wrong.
