morphs not loading/other?
KRISHANKOKRISHANKO Posts: 99
hi everyone, since yesterday i noticed my genesis 2 male models were loading strangely, as if they were starving. not only new scenes, but previously saved as well.
ive checked my other models and it seems it only affects G2M. heres how they look like
Image removed
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Please don't post images of skin-coloured naked figures, even if they lack anatomical details. You can show a morph issue, in most cases, by taking a screenshot in Smooth Shaded preview mode.
    This looks as if a morph has been saved with a non-zero default value, by you or by an add-on maker. Load the figure and in the Parameters pane Editor tab look to see what is listed in the Curently Used group.
  • KRISHANKOKRISHANKO Posts: 99
    edited April 2017
    sorry, didn know. according to the tab. the only thing currently used is "render subD level (minimum)" and set to 1.
    reseting it doesnt do anything.
    edit: how odd, it didnt show on currently used but when i manually checked my morphs, i found one that was set as 1 on default. reseting it to 0 placed the model back to default. how do i make that morph to stay at 0? models still load with that morph at 1.
    Post edited by KRISHANKO on
    Try opening the Parametrs pane option menu (the lined button in the top corner, or right-click the tab) and enable Show Hidden Parameters - do more items appear under Currently Used then?
    yeah, a lot of them, locked. i unlocked and reseted them and the new model also went back to default.
    but when loading a new model, they still load wrong.
    edited April 2017
    We need to figure out which product is causing this - then you can either remove it pending an update, fix it pending an update, or if it's a Daz item report it as a bug. Which morphs were non-zero (check with the pose zeroed - also an option in the Parameter pane option menu, Zero>Zero Figure Pose -  so there are no joint adjustments to confuse the issue)?
    edited April 2017
    its the kytis monster from renderosity. its body morph loads at 1 instead of 0. but not the head. is there a way to keep the morph at 0 witouth having to manualy do it every time i load a model?
    Well, you should send a message to the vendor asking them to update but in te mean time:
    1. click the gear icon on the slider for the problem moprh and from the menu seelct Parameter Settings
    2. change the default value to 0 and click Accept
    3. File>Save as>Support Assets>Morph Asset, select only the morph that you just changed, and keep the other settings the same.
    thanks man, this should fix it for now while i decided to keep the creature ATM or not.
