Error making clothes?
CherubitCherubit Posts: 995
edited April 2017 in New Users
I made a shirt and made it follow my G3F.
However, whenever I use some morphs, or some poses, it looks pretty bad. (in the image, check under her breasts).
How can I do to fix that? Then how do I save it?
I want to make it so that no matter the pose, the shirt will look good...
400 x 356 - 44K
Post edited by Cherubit on
  • Richard HaseltineRichard Haseltine Posts: 112,346
    Custom morphs, instead of the auto generated morphs, for the shirt (so you can pull it out of the crease under the breasts or brdge the cleavage) for those cases where a morph looks bad (or you may in some cases be able to make a universal morph that can handle a range of shapes - a lot of items now include a breast bridge morph for example, which can help with the fabric getting stuck in the cleavage for any shape). For posing either adjust the weight-maps or create morphs to fix the issues and use ERC Freeze to link them to the transform. There are several helpful videos in the Daz Youtube channel
    https://www.youtube.com/channel/UCtqhpxQyGa7fm0LPoDz4s4A
    https://www.youtube.com/user/WWWDAZ3DCOM/videos?sort=dd&shelf_id=4&view=0
  • CherubitCherubit Posts: 995
    Thank you Richard!
    I cant find specifically which one of the videos suits me :( (i just got a list with all of them).
    So I make one specific morph for each movement/pose? wont the morphs collide if I lift an arm and bend the genesis back for example?
  • tentmantentman Posts: 108
    Typically you need below steps to make poseable clothing.
    1) Adjust weight maps. The trick is 'not too much modify'.
    2) Adjust autofit JCMs using modelling program and overwrite it. In your case, target JCM is pJCMChestFwd_35.
    3) Make your original JCMs on non-autofit distorted parts.
    4) Adjust character FBMs using modelling program kind of FBMVictoria7 and overwrite it.
    5) Adjust shape FBMs using modelling program kind of FBMHeavy and overwrite it.
    6) Adjust PBMs using modelling program kind of PBMBreastsCleavage and overwrite it.
    7) Make your original adjustment morphs. Kind of 'Adj Breast Bridge'. Never forget include 'FBMExpandAll'.
    Hope you can read my poor english :)
