Animate 2
I purchased Animate 2., but when I go to the pane's tab it shows only animate lite and animate two constraints. When I select two constraints, it says it not available in Animate Lite.
Sounds like you either didn't install it in the right location, or you installed it properly, but haven't yet registered it. You need to do that with the serial number they provided You dfo that in Help->.About Installed Plugins. When you see the gree plug beside the add-in, you know it's installed and registered.
