General Technical Question
Question 1: Once I have a Genesis figure dressed with hair complete. Can I save that figure so that when I create a new scene, I can just load it from the content library menu?
Question 2 In the studio Paris, how can I replace the image on one of the provided paintings with pictures of my own?
Question 3 How can I make a mirror reflect the image standing in front of it?
Question 4 How can I make one of the short dresses longer?
  • fastbike1fastbike1 Posts: 4,085
    1. Several choices. To me the easiest is to save as a Scene Subset. When savinh you can select what things are being saved. When you want to insert in a scene, just go to the scene subsets folder and double click your deisred subset. It will merge into the scene.
    2. One way is to maek a primitive plane the size of the image and parent the plane to the image (ovelay the primitive and right click , select parent). Click the primitive plane and select the surfaces tab, click the image map drop down and load yourjpg image. Your jpg will have to be sized to the correct dimensions first.
    3. If it's an Iray mirror you shouldn't need to do anything. If not, select the mirror, go to the surfaces tab, load the DAZ Iray nickle shader. there are some adjustments to the properties, but i don't remember them. There is a free Iray mirror shader on Sharecg.com
    4. If you don't want to use a modeling software, the dress will have to have a longer/shorter morph.
