mutlable video cards
 im currently running a 980ti and im running a 1100 watt  powersupply, if i were to buy a 1070 or a 1080 or ti verson could i still run both cards and be fine with my video card i dont have much drawing power except 32 gigs of ram a  i7 3770k 4 hds and some fans
  • dragotxdragotx Posts: 1,149
    That big a power supply will be fine for both cards, it should be able to handle two titans with no issues.
  • MattymanxMattymanx Posts: 7,002
    edited April 2017
    Also the new Pascal cards use less power then the 900 series cards
    However, when in doubt, check a wattage calculator to see what you're using or going to need - http://www.coolermaster.com/power-supply-calculator/
    Having just calculated mine, it tells me Im running about 966 watts so my 1600W PSU was a good choice as it leaves plenty of room for expansion
    Post edited by Mattymanx on
