shaders plus
Hello! I need to install shader plus, from Digital carvers guild, but it seems to be un-recognized by carrara 8.1.1.12... same in the beta version of 8.5... anybody has tried to install the DCG plugs in the last version of C PRO ???
Yes. I have installed Enhance:C and Terrain Tools just a few weeks ago.
As with most (all?) Carrara plug-ins, simply copy a few files into the Extensions folder. Make sure that you have copied all the files.
For the record, DCG is extremely helpful and responsive; so if the forum posts here don't help you resolve, contacting DCG surely will.
I have Enhance:C, Shaders Plus, Shader Ops, Shader Ops 2, and Anything Goos - they all work quite nicely under 8.1.1.2
Make sure you put the right files in the directory: 32 vs. 64 bit, Windows vs Mac.
I don't recommend trying to organize your "Extensions" folder: put everything in the main folder - no sub-folders.
thank you for your answers!!!... as I have the same problem with shader ops, and shader plus, I'm answering that the fact to be under that damned f... Windows 8 is'nt the problem... I remember, with win 7, it was very simple: dragging in extension folder, wrinting once open C8 the serial number, and that's done!...
