Clothes morph parenting?
Is it possible to use one set of clothing to morph another by fitting one on top of the other?  I'm not sure how to describe this.
But, let's say you have a piece of conforming clothing with a lot of morphs.  Can you make this piece of clothing invisible and parent another piece of clothing to it to use some of the invisible clothing's morphs?  I realize the results might not match.  I just wondered if it were at all possible.
  • SixDsSixDs Posts: 2,384
    What you are describing might work using smoothing and collision, with or without parenting.
  • Richard HaseltineRichard Haseltine Posts: 112,038
    Yes, you can fit one piece of clothing to another and have morphs transfer as they do from a base figure. You can also, as SixDs says, have smoothing and set collision target to another piece of clothing isntead of the base figure. The two options are independent, you can use, one, both, or neither.
  • Cool...I'll have to try that.  Is there a good tutorial on this?
  • There never seems to be an actual Tutorial for what you really want!! LOL
    I'm not sure what you want a tutorial on - it's just a question of chnaging the selection in Fit to or Collision Target in the parameters pane, with the clothing selected. If there's no Collision Target (in the Mesh Smoothing group) then Edit>Figure>Geometry>Apply Smoothign Modifier.
