MAT issue
I am fairly new to DAZ so please forgive my ignorance. I brought up a genesis figure and added "four arms" to it. After I got the image I was looking for I added the Mr. Hyde MAT to it. The problem is in the "four arms" portion. The MAT did not cover the armpit portion of the figure (See image). Any insight, anyone?
  • Richard HaseltineRichard Haseltine Posts: 112,346
    Please don't post images showing nude figures - in this case it would have worked to zoom in a bit further so that the groin was out of view.
    Unfortunately only a texture that was made for use with the Four Arm add-on will reliably match at the join - one with relatively little tonal variation between the sholder area and the abdomen may not be too bad, but one with a marked diffrence will, as you've found, give a clear break. You might be able to make it less obvious by adjusting the Diffuse colour to tone the texture on the extra arms to be closer to the texture on the torso.
  • Thanks for your input. I will keep the image issue in mind. There was no genatalia involved so I didn't think it inappropriate. Sorry.
