Missing Emissive Button
I recently had to uninstall DAZ Studio and when I went to reinstall it I decided I had way to many things installed. I tried to install everything I thought would work for DAZ, just Genesis 3, and Iray to simplify things. When I started up DAZ most of it worked fine and faster than before, but my Emissive button under the surfaces tab is missing and I can't seem to figure out what I need to reinstall to get that to work again. Can some one tell me which Item the Emissive button is installed with?
  • Richard HaseltineRichard Haseltine Posts: 112,346
    Have you applied the Iray uber base shader, or better the Emissive shader preset? That's in the Defult Resources package.
  • CoryRose40CoryRose40 Posts: 25
    edited March 2017
    Default Resources for DAZ 4.9 is installed. I uninstalled it and reloaded the program. Its still not there.
    Edit...I restarted Daz a third time and checked again and there it was. Never seen the program require 3 reboots before. Very weird and my system is set up quite well too. Thanks for pointing out my mistake. Thought I was missing a package install and it ws one I had installed already that didn't install right. Haven't had that one pop up before.
    Post edited by CoryRose40 on
