Is there a split morphs script?
Masterstroke
I made myself a sitting morph for a G3F dress. Works nice, but I'd like to have that morph for each leg movement individualy, so I need to split the morph to each body side? Is this possible inDS? Is ther a script for it?
Do bear in mind that if you split the morph you will get odd results with only one leg bent or with both - generally this needs an overall morph to fix the combination if theera re separate morphs for each leg.
Morph Loader Pro has attentuation options - at the bottom of the settings under the morph name. For a smooth transition you probably want to create a weight map (using a DForm) then select that as the source of attenuation when loading the morph, then either use a second DForm for the other leg or invert the attenuation effect when loading the same morph for the other leg.
