Recent scene load errors
When I load a recent scene I seem to get these errors: Shoes that were fitted to a modified morphed G3F - return in "unftted" position and can'y be re-parented? Also items added after reload will not be added to Reality 3D render scene? Using 4.9. Any insights appreciated.
  • Richard HaseltineRichard Haseltine Posts: 112,346
    Are the non-fitting items things that were made for the figure or are they AutoFitted?
  • Are the non-fitting items things that were made for the figure or are they AutoFitted?
    They are bought items for G3F and then auto-fitted.
    If they are for Genesis 3 Female they shouldn't need AutoFit (the conversion process) - but they will use Auto Follow to match morphs. Is that what you meant, or have you saved your modified Geensis 3 Female as a new figure?
  • If they are for Genesis 3 Female they shouldn't need AutoFit (the conversion process) - but they will use Auto Follow to match morphs. Is that what you meant, or have you saved your modified Geensis 3 Female as a new figure?
    The modified G#F is saved in a scene - not specifically as a discrete figure/character. When I re-open scene the shoes do this jump to what seems a new(or old) bone structure.
    I'm not sure what to suggest - you could try saving everything as a new Figure asset, to break the link to the existing versions, assets do tend to be safer.
