Can't make a connect
I enter my email and password and I see an error
  • Richard HaseltineRichard Haseltine Posts: 111,965
    Your image isn't showing, even if I copy the URL and paste in a new tab.
    Not a very informative message, is it? After the failed attempt to connect, please go to Help>Troubleshooting>View Log and scroll to the very end - if there are any messages there that look releated to the connection issue please post that section of the log here.
  • I can't open the file. It open a window of file selection.
    edited March 2017
    It's a text file - it should open in the default application for plain text files (such as Notepad on Windows). You can open it directly from C:\Users\Your name\AppData\Roaming\Daz 3D\Studio4\log.txt (AppData is a hidden folder so you will need to enable the dispaly of hidden files and folders).
    2017-03-08 23:46:22.081 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: ERROR:  relation "customer" does not exist
    LINE 1: SELECT * FROM "customer"
    2017-03-08 23:46:22.081 WARNING: cloud\dzcloudtasknotifier.cpp(178): Query (SELECT * FROM "customer") failed with exception: ERROR:  relation "customer" does not exist
    2017-03-08 23:46:22.082 WARNING: cloud\dzcloudtasknotifier.cpp(178): Query (SELECT * FROM "customer") failed with exception: ERROR:  relation "customer" does not exist
    2017-03-08 23:46:22.082 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: ERROR:  relation "customer" does not exist
    2017-03-08 23:46:43.231 WARNING: cloud\dzcloudtasknotifier.cpp(178): Query (SELECT * FROM "customer" WHERE remote_customer_id = '3420249') failed with exception: ERROR:  relation "customer" does not exist
    LINE 1: SELECT * FROM "customer" WHERE remote_customer_id = '3420249...
    2017-03-08 23:46:43.231 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in runNextTask-runTask: ERROR:  relation "customer" does not exist
    2017-03-09 00:04:18.409 Iray INFO - module:category(IRT:RENDER):   1.1   IRT    rend info : Shutting down irt render plugin.
    2017-03-09 00:04:18.507 *** Scene Cleared ***
    2017-03-09 00:04:18.560 DEBUG: End DAZ Studio to Hexagon Bridge log...
    2017-03-09 00:04:18.601 --------------- DAZ Studio 4.9.3.166 exited ------------------
    2017-03-09 00:04:18.601 ~
    Are you copying the email from a sales receipt email or the like? It looks as if it is not recognising your account at all, which would suggest there's an error in the address.
  • No. I enter it on the keyboard.
  • morkmork Posts: 278
    I know it's old, but you might end up here when searching the web for this, like I did.
    If you're on linux, check this thread:
    https://www.daz3d.com/forums/discussion/60901/daz-studio-and-linux/p25
    The problem you have is that the database in PostgreSQL does not exist, or it is missing the structure. Installing something with DIM will fix it, given you have a working installation of PostgreSQL already (installation instructions on page 6, same thread. Use "Content" for the database name though, to bypass troubles by DAZ3D ignoring the custom database provided via cmscfg.json) and told DAZ to use it.
