Is there a SSS guide for dummies.
JohnDelaquioxJohnDelaquiox Posts: 1,197
I have to be missing something because I am unable to see the SSS area under diffuse in the surface tab.
So is there an SSS guide for dummies
  • SzarkSzark Posts: 10,634
    SSS is not part of the Daz Studio Default Shader but part of HSS (Human Skin Shader), Uber Surface which ae both part of Daz Studio found in the Content Library Pane (NOT SMART CONTENT) under Daz Studio Formats > My Library > Shader Presets > omnifreaker >
    WHen loading these shaders and you wnat to retain the original texture maps hold down Ctrl while double clicking on the presets, then for the Map Settings choose "Ignore".
    Besides the help icons found in the same place as the shaders there isn't much in the way of diffinitive facts about what each channel does or how it works. But if you use Google to search you should come up with some information scatered here and there.
  • JohnDelaquioxJohnDelaquiox Posts: 1,197
    Thank you both!
  • SpitSpit Posts: 2,342
    pwSurface also has SSS but it's extra. Under Studio 2 there was a scripted help function with good interactive explanations of all the parameters. I think it broke in later versions and never recovered though the updated shaders work fine. What I had the most trouble with, in a general SSS sense, was choosing the proper scattering color.
  • ReDaveReDave Posts: 815
    @Spit: I don't have the pwSurface, but in general scattering is the opposite of the colour you wish to come out. So for human skin it would be some sort of teal/blue (i.e. mostly blue, middle green and least amount of red).
    Thanks, reDave! That's a big help!
  • KeryaKerya Posts: 10,943
    Is that why Poser renders with SSS often have a blue mouth syndrome?
    edited January 2013
    Sorry Kerya, no idea! But it's certainly possible. Is that SSS in Poser 9 or older versions too? I have P6 and P8 only.
    Post edited by ReDave on
  • RawArtRawArt Posts: 6,214
    Not sure if this is what you are looking for, but I wrote this for putting together sss in d/s.
    http://rawart3d.deviantart.com/gallery/37253370#/d52mlpi
    To get the options in your shader tab, you have to go to "Presets/omnifreaker/HumanSurface" and apply it to your figure first.
    (or simply apply textures that use it)
    Rawn
    edited January 2013
    Real SSS is only P9 up.
    Older versions of Poser only had faked SSS called Fast Scatter.
    Nice faked SSS on humans for free by Bagginsbill:
    https://sites.google.com/site/poserbagginsbill/vsshomepage
    Edited to add: this was an answer to ReDave's question about SSS in Poser
    Post edited by Kerya on
    Rawn
    Thanks for weighing in. I read your tute, thank you. Interesting that you also used velvet. Nice idea.
