Quad Models
DesignerbobDesignerbob Posts: 0
Does anyone understand the steps to make a Quad model?
    Hi DB, by "Quad", do you mean a mesh made of quad polys?
  • 3DAGE3DAGE Posts: 3,321
    Hi Designerbob :)
    Yes :)
    INSERT / Vertex model...
    then create a square / rectangle, and then extrude it into a cube, then (CTRL+F) to fill the top and bottom polygons,...
    That gives you a starting "Box" to begin the process of "box modelling".
    OK, that's over simplified,. but you did ask :)
    There are many different tools and features in Carrara's vertex room to enable you to produce "quad" surfaces from simply extruding, to more complex surfaces created using lines for latitude longitude, or paths and shapes, and lathing.
    What do you need to know ?
    What are you trying to create ?
