Wishlist Error
trill
Sorry if this has been posted before, or if solution has been posted couldn't find any. :-) On the store product page my wishlist column show the right number of items, but when I click on the
Wishlist in the header bar I get the following error:
There has been an error processing your requestException printing is disabled by default for security reasons.
Error log record number: 568564743420
I know you are swap at DAZ, but I just wanted to know if this is just me or are others having the problem.
Thanks for your time. Also everything else works fine:lol:
It's not just you; I haven't been able to get my wishlist to load either.
If I click on wishlist from the top of this page, mine shows correctly
Chohole,
I tried what you said, but I got this error now:
At least I now know it isn't just me.
I had this problem. If you have "Crazy Nights" in your wishlist, it breaks it. There may be other products like that.
When you go to a store page, 3 items of your wishlist show up on the right sidebar, and from there, you have the option to remove them entirely, or move them to your cart.
I moved 118 items to my cart. When I got to "Crazy Nights" it threw up an error, so I just removed it entirely. As soon as I did that, everything was fine. I then moved all the items from my cart back to my wishlist (which you can do all at once by checking the boxes).
A PITA, but it fixed the problem.
Thanks Velvet Goblin, your method did the trick. It appears that "Crazy Night" doesn't want to be wishlisted. :-)
It's certainly not Crazy about being there.
Thanks Velvet Goblin!
I've been trying to get to my wishlist for days and kept getting this error:
I used your method & deleted Crazy Nights and my wishlist worked again all of a sudden! :)
I removed the item and everything worked.
What I would like to know now, why doesn't DAZ removed the item from everyone's wishlist (with a note saying it impacts viewing the wishlist)
A simple script would be easy to create for this
My Wish list is just BROKEN. I had 12 items in it. The quick link at the top of the page errors out. The Wishlist in the store shows 199 items in it and every item I try errors it out.
