Installer problems
boni_m_ab7b32f625boni_m_ab7b32f625 Posts: 113
Just baught Tele-phony ... and the installer doesn't bring up a proper path to install to. I would have to go through and figure out the exact path and type it in by hand. Granted I could go through the work to do that ... but the point is, the installers use to work. This is the second one in 2 days that hasn't. Any other xolutions?
Thank you for your time.
Boni
  • frank0314frank0314 Posts: 15,120
    There should've been a button to the right of the text field to browse to the file location
  • boni_m_ab7b32f625boni_m_ab7b32f625 Posts: 113
    There is and the fields are all blank.
    Which installer are you using. I have 2 to choose from, A dpc and a DS one.
    edited January 2013
    Follow up. On the .dpc one. ichose Poser all files, as I use poser then I got this screen.
    You then browse to where ever you want to install it on your computer.
    Remember it is a very old product, As you can see I always install to a temp folder an then move to where I want it, but that is just my work flow
    680 x 398 - 101K
    Post edited by Chohole on
    I had the wrong installer. Thanks guys. Silly me. (after 10 years dll'ing from here, sheesh)
    Boni
