Exporting Obj for Normal Map
marble
I've downloaded the utility XNormal and I want to export a G3F Obj file with HD so that I can create a normal map from the HD features. This is for personal use and it was recommended because HD does not transfer over to some geografts.
However, when I export the HiRes and LowRes images for XNormal, it will only generate the head map - not the rest of the skin zones. How would I export the torso, for example?
Check the Collapse UV box on export.
Thanks, I'll try that. :)
Nope, see attached for what I get from XNormal.
OK so in another forum I've been advised to use the Geometry Editor to select surfaces and export them one at a time. Seems like a lot of work but I'll give it a try.
