UV Problem
I'm using Daz 4.5 on Vista, in case it matters.
Here's the problem, I try to save a texture preset, either as a material or a properties preset and the UV set gets corrupted.
If I set it to M4, save, and pull it back up it shows up as K4.
I set it to K4, save and load and it sets it to V4
Genesis Male turns into M4
Genesis Female turns into Genesis Male
V4 and some custom UVs I've made are good.
I uninstalled and reinstalled Genesis essentials, but it didn't help.
Probably should try a new download...
Anyone else having this problem?
Full version number of 4.5...there's now six of them around. Help > About
Tip Never Save without LOCKING your UV setting in ANY version of DS4.
Version: 4.5.0.114
@Jaderail, I tried that. It didn't help.
DS4.5.1.56 is the lastest Public release http://www.daz3d.com/forums/discussion/14562/
Hi...
That's a known bug in 4.5.0.114.... it was fixed in the release of 4.5.1.6
As Szark just pointed out, 4.5.1.56 is the latest full release....
Hope this helps... :)
It does, thank you for your help!
