A question
Hey I'm not sure if this is the appropriate thread or whatever you call it, but if not, please forgive me. But I have a question regarding
Genesis 2. Is there a product that gives genesis 2 a skeleten or internal organs? All I seem to find is one for V4.
  • There is no skeleton or internal organ products for any of the Genesis figures. All you'd be able to do is parent the V/M4 versions to a newer figure.
  • HavosHavos Posts: 5,706
    In addition to parenting the figure as zombietaggerung describe, you might find it best to morph the relevant Genesis figure into V4's shape. I assume you will me making the skin at least partially transparent, in order to see the skeleton.
  • wizwiz Posts: 1,100
    Other way around. Autofit doesn't just let you fit clothes, it lets you fit figures to other figures. So, as long as you have a V4 autofit clone for your figure, you just autofit the V4 skeleton to your figure, maybe resize it a touch if there's poke through (which only happens in extreme figures) and possibly tweak feet angles, and you're there. I've skeletoned Genesis 2 using the V4 for G2 package and Genesis 3 using Wear Them All G3Fpossibly Theorecially, you could go through one of the "how to autofit V4 clothing to G2 or G3" tutorials floating around and do this without buying V4 for G2 or Wear Them All, but I've never tried it.
    Oh, and this also works for Cyborg Model 4 and Weapon Mech (but not ASN 4) if you want a figure with an internal robot structure. You can have a lot of fun with several figures being scanned and having most of them have skeletons and one having an internal robot. ;)
    edited February 2017
    Not really necessary. The skeleton and organs will happily autofit to anything from Ron's Massive Morphs to the stock G2 Bodybuilder down to Zev's Growing Up.
    Post edited by wiz on
    I have no idea what happened here. Could someone please delete it?
    Hmm, I thought I had tried that, and it had messed up the internal organs during auto-fit. Anyway, I tried again, and although there is a bit of distortion it is not that bad, so it appears I was wrong, sorry.
    Below I rendered G2M with the M4 skeleton and Organs. I do not have the V4 versions, but I imagine it would work just as well as the M4 ones.
    1024 x 1024 - 86K
