Is there an Unused Morph Remover Utility available?
I remember that, years ago, when I used Poser exclusively, I had a utility that would remove unwanted zero morphs (excluding expression morphs) to reduce the size of a figure.  There are so many morphs in G3 that I sometimes find myself hard pressed to do a render because I run out of memory in the middle of it.  Once I lock a shap on a character, I'd like to be able to remove all the zero values.
  • HavosHavos Posts: 5,703
    edited February 2017
    One option that will greatly reduce the memory needed is to change the figure to a prop once you are happy with the final pose. Probably best to save the figure as a scene subset first, so you can reload if you want to change the pose.
    Post edited by Havos on
  • If this is Daz Studio then the main part of the morph data - the deltas, changes in position of the vertices making the shape - will not load until the morph is non-zero. If you close DS and reopen the scene only the currently used morphs will load their deltas, which should be nearly as light as deleting them entirely.
  • CybersoxCybersox Posts: 9,922
    That makes total sense, yet I noever thought of it before.
