MillBigCat LE
Rae718Rae718 Posts: 0
I have installed the exe file several times and each time it says there was a problem... what am I doing wrong, i click on the exe file for PC and run as needed, it seems to keep uninstalling previous versions then re installs, but the only fails or does not show up in the Daz studio library.
How do we add these on?
Thanks
  • JaderailJaderail Posts: 0
    Does it Say it Failed or can you just not find it? Big differance.
    Short Explanation of Content ONLY Updated or New Content will be found in the Smart Content Tab. All older Content will be found in the Content Library Tab (Window>Tabs(Panes)>Content Library.)
    Then you look in both the Poser Formats>My Library for your Content
    And in the other Daz Studios Formats>My Library for the DS version of the content if Supplied.
    This assumes you installed the content to your My Library Folder.
    I hope this helps you find your missing content.
  • Scott LivingstonScott Livingston Posts: 4,352
    I use Windows 7. Sometimes when I run an installer for an older product (and the Millennium Cat LE) would qualify as "older," after the installer runs, I get a pop-up message that indicates that the installation may not have run successfully. Is this what you're referring to?
    The good news is, it's almost certainly a false positive...chances are, it did successfully install. So just dismiss the pop-up (I believe there's an option to tell it that the installation was successful). You should be able to load the Millennium Cat LE without a problem.
    If there is a problem, then I'd try re-downloading the installer. Hope this helps!
    Not entirely a 'false positive'...the content itself has installed correctly and finished. It's either installing the shortcuts or document files that's failing...but in either case, non-essential items that don't affect the usefulness of the content itself. In fact, sometimes what doesn't get installed is the desktop shortcut to the store...which I count as a feature!
