Configuration Error
Daz Studio 4.9 Pro will no longer link up to my account. I'm getting the following message:
"Configuration Error
Configuration of the system has changed. To use content installed using Daz Connect, the content owner must re-authenticate"
Help!
I can help with this because it plagued me for months. I reported it late last year and was advised to log in through the Smart Content pane, rather than using Menu> Connect> Login. That worked for several weeks, then the message began to appear again. In early January, Tech Support told me to follow the steps outlined below, and I haven't seen the error since. It *appears* to be fixed completely. Below are the steps they gave me.
I was installing from the manually downloaded .exe, but if you're using DIM, it should be just the same process.
And what happens when you try to log in, from the opening dialogue or from the Connect menu?
Ok, thanks for the help. Bloody hell, this looks hideously complex and scary to a computer illiterate like me. :(
Actually, it's really easy. Basically all you do is uninstall DS (you should have that option in the Start menu), find the folder and delete it, then re-install DS.
