Making props
How do I go about saving parts of a scene into their own prop file. IE. I have a model of a spaceship bridge that I want to save the different parts as props seperate from the full scene.
  • KindredArtsKindredArts Posts: 1,360
    Is the model already broken up in your scene? If so, you can save each part as a scene subset or figure if you don't want it to be dependent on the original obj/fbx. If it isn't broken up in your scene already, that should be done before import really.
  • There is Daz3D prop product called "Symphony for Reflections Vanity".   In it, there is a 3 panel room divider with cloth material covering each panel.   How can I change that material to a reflective mirror texture and thus make it into a 3-panel mirror?     thxs in advance....
    Are you using 3DL or  Iray?
