Can I use a M4 Morph on Genesis?
Hi,
I have a M4 morph (Jepe's Adrian) that I would like to use on Genesis. Is this possible? I know I can use the texture, but it is the facial morphs that I really need. All the clothes and poses that I want to use are only for M5/Genesis...
It can be done fairly easily with the GenX plugin, but you also need the M4 shape for Genesis as well.
There are a number of threads on the subject of using GenX to transfer characters scattered around the forum, and I'll see if I can find one for you if you are still interested?
Thanks! Any links would help. I have the M4 shape and will look for the GenX plugin.
Here are some links that may help:
http://www.daz3d.com/forums/discussion/1599/ How to transfer
http://www.daz3d.com/forums/discussion/5878/ Main thread for the update to 4.5
This one is not really GenX, but it may help also
http://www.daz3d.com/forums/discussion/4760/
There is very good documentaion which comes with GenX as well in the form of a PDF. If you get GenX, and have any problems, I'm sure someone here will be able to help more. I have the GenX plugin myself, but haven't used it much.
Just found this too, a tutorial on GenX.
http://takoyakida.webs.com/apps/blog/entries/show/13803069-genx-plug-in-tutorial
