Rigging help
Oso3D
Trying some basic rigging and getting very confused.
So I make a cylinder. I use Geometry editor to divide it into three surfaces, export as obj.
Now, from what I read, I should be able to open Figure Setup, Add Geometry and point to that saved obj. It should then list the three surfaces I made.
But it doesn't. It only gives one surface, 'default.' If I import the obj, it has three surfaces, so it didn't get erased along the way.
What gives?
Figure Setup does not list surfaces, it lists vertex groups and generates a bone for each. If you want things to show up in the FS tab you need to assign them as vertex groups (also something you can do in Geometry Editor).
Aaaaaaaaaaaaaaaaaaaaaaaaah. Thank you. ;)
