render setting
jimlinjimlin Posts: 146
can i set render settings to pale 720 x576 if so how when i try this setting does not set
  • Make sure the preset isn't set to Active Viewport.
  • barbultbarbult Posts: 27,500
    edited January 2017
    You will probably also need to turn off Constrain Proportions (Global).
    471 x 378 - 156K
    Post edited by barbult on
  • jimlinjimlin Posts: 146
    Thanks for your responce ive done that but i want aspect ratio of 16x9 not 5x4
  • KnittingmommyKnittingmommy Posts: 8,191
    edited January 2017
    You can put in your Aspect Ratio but that will modify what your pixel size is set at.  If you set the aspect ratio to 16 x 9 and put 720 in the width for Pixel Size, there is no way you are going to get 576.  720 x 576 is an aspect ratio of 5 x 4.
    548 x 821 - 60K
    Post edited by Knittingmommy on
    I Have made loads ofpale dvds and they are all 720x576  16x9 720 x 405 is for ntc american format i have pinnacle studio 12 and 16 Hitfilm iclone 5  they all output 720 x576 as 16x9 pal
